exhaust fan placement
jfhicks
Hancock MI
I have a have 20x30 garage with a hot dawg heater in one corner. I am wondering if any one has any recommendations for where to place a through wall exhaust fan to decrease the hot air from the heater to pulled directly out side when fan is in use.
ripperd
Twin Cities, MN
What are you intending to exhaust? To reduce how much heat you discard I'd use some kind of fume extractor to get at the source of the fumes.
bimmer1980
York, PA
Good comment above.
You may want to consider a good filter system to simply clean the air...i.e. for dust and welding fumes.
Engine fumes would need to be exhausted.....
J
jfhicks
Hancock MI
It would be for manly welding fumes. I live in Michigans upper peninsula and It gets cold and snowy here so I cant open the garage door for long periods of time.
ripperd
Twin Cities, MN
Welding fume extraction and filtering is a very common need. You definitely will find what you need using those keywords with some internet searching.
