ToddW
As pointed out by ARD above, the length of the overhead and underground service lateral and the 400a dictates VERY large wire to combat voltage drop. Plus PoCo most likely would need to retrench and lay new pipe.
But perhaps instead they wouldve ran high voltage primary over or under that 400' then set a pad mount transformer which would get rid of the voltage drop problem over that distance.
The $15k quoted seems more likely to be for a pad mount transformer...
Who is your PoCo? PG&E?
Yep, PG&E.
Do they do pad mount transformer in snow country?
We try to avoid aerial due to living in the forest and high winds not to mention once the wires are on my property I HAVE to maintain trees/safety/etc... I can also trench myself and no concrete drive,etc to deal with.
Sorry to get off-track I'll post any questions in my own thread
Did it on a bootleg panel swap where the idiot(s) chose not to use the supplied hub gasket & the water infiltration played havoc with the aluminum bus.
