Expanding foam between plasterboard and concrete floor?
GB8
Northern Ireland
There is a gap at the bottom between the plasterboard wall and the floor in my garage which I believe is standard procedure.
I have used some cheap wood to cover the gap, should I take the wood off and fill the gap using expanding foam then put the wood back on to cover it?
Lots of bugs getting in and I would like to seal it up.
See picture attached.
Bondo
Greenfield, Maine
Ayuh,..... That's a water gap, so the drywall won't **** up moisture from the floor,.....
Fill it in, 'n you defeat the purpose,.....
Stoppin' the bugs, starts Outside the building,.....
