As long as the depth is not more than 1/2", SikaFlex will work. However, SikaFlex is a joint sealer / filler that should not be used to apply coatings over. For this application, we would recommend filling the joint with clean silica sand instead of backer rod. This is due to the fact that the OP does not want creeper wheels to get hung up. With such a wide joint, if a wheel rolls long ways into the joint with the backer rod, it could possibly punch through the sealer or sink down too far since the backer rod is not supported underneath.
