Expansion joint covers
G19Tony
Las Vegas
I'm close to deciding on flooring. It's going to be between RD and just sealing the concrete. If I seal the concrete, I'd like to use expansion joint covers, so I can roll tool boxes and other stuff around. What are you guys using? I don't want to permanently seal the joints, just cover them up.
Thanks. :beer:
Tooslow
I used foam backing cord from Home depot with a self leveling concrete sealant. The sealant was in a 29 oz tube and the backing cord allowed me to use less of the sealant.
nehog
Jaffrey, NH
Just how big/wide are these expansion joints? (Maybe a picture, with a ruler for size would help...) The cut joints on my floor don't affect my toolbox rolling.
G
G19Tony
Las Vegas
Why do you not want to seal the joints?
To answer your question, I've installed these before. Seem to work well. I would search out a pro if you are not one. A rep would be able to find you one locally.
http://www.balcousa.com/Expansion-Joint-Systems.cfm
I was always under the impression that you don't seal expansion joints. It's a moot point anyway. I'm going to order RaceDeck tomorrow. :thumbup:
pd59
Texas
You can seal expansion joints, you just have to use something flexible that allows the joint to move without damaging the seal, like a polyurethane caulk, a flexible epoxy, or even a fast curing polyurea (although this choice can be pricey).
Regardless, you will enjoy the racedeck. Wish you luck on the install. :beer:
