Expansion Joint
lassanter
Canton, Michigan
Good morning from a new member!
I am, at last, beginning the lifelong dream of restoring a car. I am planning on putting the vehicle onto wheel dollies in order to allow me to maneuver the car a bit in the garage. However, I am concerned that the casters of the dollies, themselves, may get stuck in the center expansion joint of my 2 car garage. Is it possible to fill this with a material that would allow me to roll the car over it, while retaining its ability to do its job as an expansion joint?
ConCretin
Central Maine
Not sure what you have but it sounds pretty large. There is really no need for an expansion joint in an interior garage floor. Concrete shrinks quite a bit when it sets. After that there is a little thermal expansion and contraction but it doesn't amount to much. I'd grout it solid.
pima67
Tucson, AZ
Maybe the jerks who poured his floor were like the ones that did mine. My garage floor is part of the house slab and is post tensioned. But they troweled in rounded V "joints" in a 9' by 11' rectangles. The only small crack I had before putting epoxy on the two 4' wide steps on 2 sides of the garage, occurred where the steps met at a right angle. I filled it with some thin set I had on hand. It doesn't show up thru the red epoxy.
Armorpoxy
We offer a Crack Repair Epoxy Putty that is stronger than concrete, it gets applied like spackle into the joint and should solve your concern.
Kaizen
New England
