expansion joints - another ques
macguy787
Edmonton, AB Canada
Has anyone tried NOT filling expansion joints?
I'm planning to use PPG Aquapon but the instructions don't state anything about crack filling.
http://www.garagestrategies.com/ppg.htm
Could I just use playsand and leave 1/8" to the top of the crack and then epoxy?
My local paint / hardware stores have been pretty un-helpful when it comes to something like this.
willymakeit
Springfield Mo.
Backer rod and a urethane caulk that matcks your floor color. Sonneborne is one of the companies for caulking. I dont think the com. grade caulks are sold at the box stores. The epoxy over sand I think would fail over time.
Dmtalon
I did not fill my expansion joints. Mine are rather large and divide the garage into 4 parts with a drain in the center. I just used a brush to make sure I got the epoxy on all parts.
I used epoxy-coat.
cowboyjosh
I always caulk (I have a caulking subcontractor who takes care of this) around the perimeter of the garage where the floor slab meets the foundation, and then myself I also fill the expansions with SIKA self leveling sealant that can be bought at Home Depot, even large joints, I typically don't use a backer rod, and so far on dozens of homes, no problems; also no epoxy has really failed on the caulk either. Here in Colorado I like to caulk as many concrete joints as possible to keep expansive soils at bay, and less water under the floor or driveway via expansion joints less chance of heaving.
Dmtalon
Here's a picture showing my expansion joints/water drain paths...
