Re: My experience with Acid Staining & Single-Part Polyurea
Some follow up on my experience with acid staining and polyurea.
Bought a couple of sample colors that my wife chose to pick from. First picture is after the acid is on but before neutralizing and mopping.
And after neutralizing by mopping with a ammonia/water solution.
My youngest son Wes used Gorilla Tape to mask off the door thresh-hold, floor drains, water hydrant, and overhead door. This tape worked great for the job, by the way.
The floor after spraying on the acid stain and neutralizing. It took a couple of cycles of mopping and drying to get all of the residue up.
And after the 2nd coat of PolyUrea. The second coat was a little difficult for me to see where I had already rolled it, but not too hard. Thought it was worth mentioning.
Also worth mentioning. This stuff tacks up pretty quickly. My floor dried for a week after mopping with water, and the humidity was low at 20% (very dry for Ohio). I tried to touch up a spot with the roller and it was a bad idea. VERY sticky! I started in the corner of the 40' end wall and rolled from the wall to the first cut line at 8' out, and worked that 8' out down the whole end wall. By the time I went back to start the next 8' section along the side wall the spot where I started was so sticky it almost tore the roller napping.
So commit to the job and keep at it until that stage is done.
Long term - it has been down since November 2020, it is now March 2021 and it has seen daily vehicle traffic, heavy roller cabinets, engine dollies, and a snow-covered skid-loader which leaked thick oily crud like only old equipment can. EVERYTHING mopped right up with soap and water, and it looks like new. Very satisfied.
Oh, and if you have fiberglass reinforcement strands in your concrete they will be slightly annoying if you don't get rid of them before coating. I overlooked this on the first half, and while they act like anti-slip treatment somewhat I would much rather they not be there.
On the second half I took a propane powered weed-burner torch to the floor first and it got rid of the little strands poking out of the slab.
Hope this helps someone trying to decide. If you like the look of it you will love the performance of it. I sure do.
