shooting4life
- Joined
- Nov 19, 2012
- Messages
- 334
I have an 18 foot wide by 23 foot deep garage. The two walls that are not adjoining to the house are currently ¼ ply wood attached to a 2x3 nailing strip on the bottom, center and top of the wall. This makes it so that nothing can be hung from the week ply wood unless you are attaching directly to the nailing stip. The walls are 2x4 studs but the nailing strips were needed because it added the additional clearance at the bottom of the wall for a natural gas pipe. I don’t want to move the gas pipe so if a wall covering is used it will have to be raised off of the studs.
The current set up is not functional since I cannot hang anything on the walls. I want your thoughts on a couple of solutions. The first would be to take down the ply wood and add additional nail strips beneath the wall and put the thin ply wood back up. I do not want to spend the money for 10 pieces of thicker ply wood at this time. The second option would be just to take the plywood and nail strips down and have an exposed 2x4 stud wall. Then hang/install whatever I want to the studs. The electrical will be ran in conduit on the outside of the wall even if the plywood is reused. What do you think about these two ideas?
I do not want to drywall and I don’t have a problem with the way exposed studs look for a garage. I live in a very moderate climate area. The hottest it will get outside in the summer is about 85 F and the coolest it will get outside in the winter during the day is 50 F. I don’t work very often in the garage, maybe 5-8 hours a week so the temperature is not an issue for me.
