Lucid Moments
So I do most of my work by myself and find myself occasionally needing to get stuff out of my truck that weighs more, or is bigger than, I can conveniently lift by myself. As an example I picked up a tanker desk from u/Pathfinders today. As a desk it is fairly heavy. Certainly more than I can lift by myself. But at the end of the day it is still just a desk. It might be 200 lbs. Four people put it into my truck very easily.
I was trying to unload it after I got home. By myself. I couldn't get it done. One way I tried was to extend the arm on my Atlas PV10P lift as far as it would go to see if I could use that to suspend the desk. Unfortunately it would not reach far enough to lift the desk.
The arm is a piece of square tubing roughly 3.25" X 3.125". It is retained by a set bolt and would be easy to replace.
The question is could I replace that with a longer piece of steel and use that to lift things out of the bed of my truck. Clearly I am not talking about truly heavy items. Off the top of my head I am thinking 500lbs tops. Clearly the issue here isn't the strength of the arm or hydraulics, but the balance of the load and the strength of the anchors in the concrete at the base of the lift column. How much is safe? If I add a counter weight does that increase the limit or just further unbalance the load?
As usual all thoughts are welcome.
