Extending the chimney clay liner?
remagenman
In my ongoing saga of trying to get sh....stuff done around the house I lean on the shoulders of experienced home owners again.
So, my chimney has a concrete cap to block the rain (home built 1973) which needs to come off for a modern metal cap.
Unfortunately the clay liner is flush with the top of the chimney mortar so I have to either extend the liner or figure out some other system.
okay, just went up to my roof and took a picture of the liner, I dont think its clay but concrete. Heres a pic.
Uncle murph
Harford county
The top of the flue liner doesn’t look like clay to me but I don’t understand why you want to raise it?The top cap has clearly seen better days,if it was me , I would get a piece of stone and set it up there.If you really do need to extend the liner,terra cotta liners are 13 x 13 and easily cut with a inexpensive diamond wheel in a 4” grinder.
Hilltopmasonry
You cannot simply add another clay liner on top of that, because on a windy day, it will blow off, since the joint is above the concrete cap
R
remagenman
After realizing I didnt have a clay liner I'm not planning on extending but just getting a rain cap that will cover the whole top of the chimney, suckers are expensive for not much more than a baking tray with chicken wire!
Jackfre
N CA
What are you venting with this chimney? For the record NFPA 211 regulates the construction of masonry chimneys. Check it put. Without a liner you may have insurance problems if the worst happens. That flue is enormous.
R
remagenman
Man, I'm getting deeper into the fireplace rabbit hole!
I've never used the fireplace but it came with a Fisher fireplace insert with no steel liner but original cement brick liner, not clay.
From what I have been reading it seems like I need a boot to properly insert a steel liner into, the damper is just a hole with the damper hole going across it, the boot will sit on top of both.
The good new is that I removed the side shrouds and saw that their is a metal pipe coming out the wall thats been capped off, I assume its a natural gas line because I have a natural gas stove outside.
