Kevin54
MEMBER EMERITUS
Correct and correct again.
Not true. The image above will provide two different torque ratings.
In the interest of ending the argument:
I'm going to have to agree with DSL. Although a wrench at a right angle to the torque wrench does not change the length of the torque distance, doing it that way allows for all sorts of errors. I would say that if you had three people torquing three bolts of equal length, you will find that all three readings will vary. For one, you are pulling on the torque wrench, but if not pulled the same way by all three people and all standing in the same place, they will pull on it differently. One could torque a bolt and be nowhere near close. If person number two pulls on the torque wrench, and person number three pushes on the torque wrench. It would be possible to click the wrench and not even move the bolt.
If I get some time today, I'll set up an example and take some pics. Here's a quick sketch as to what I'm talking about. I would thing that a wrench straight out of the end of a torque wrench would give a more consistent reading. Not accurate, but consistent. over one being at a right angle. One would have to figure out the difference in torque because of the length difference.
