PugetDude
Extension is essentially a solid shaft made of steel. If you want to calculate the "twist" also referred to as "angular deflection" - here is the formula for solid shafts.
https://www.engineeringtoolbox.com/torsion-shafts-d_947.html
Let's look at this formula and what it means.
L= length of the shaft - longer shaft, more twist.
T= torque - more torque, more twist.
J= is a geometrical factor calculated for shafts - bigger J, less twist
G= modulus of rigidity - bigger G, less twist
G is called - modulus of rigidity.
Here are all the examples of "steel" from the table in the link above;
Notice how similar the number is for different types of steel. In all likelihood the variation you find in steel used in extensions is so small it's impossible to detect or feel. Even difficult to measure with advanced equipment.
So basically, take a look at any extension, the only thing you need to know about it regarding twist is the diameter and length. And notice according to the formula above the twist or angular deflection is inversely proportional to the diameter in forth power. Meaning - small increase in diameter makes BIG difference in twist (less twist actually).
Ps
This formula is only valid in the elastic zone and tells you nothing about when your extension fails. Then different material properties come to play.
Olafur, good analysis, but you left out "snapunobtanium" the miracle alloy used in all Snapon tools. Snapnobtanium's unique ability to increase yield strength, notch toughness, torsional load, and corrosion resistance is only activated by special cryogenic conditioning bins on the ice cream truck. . , and continues to increase in direct proportion to the length of time the purchase is financed.
