HoosierBuddy
Hey guys.
Sorry for a sort of off-topic question...but I'm not sure what to do.
My house has a bumpout breakfast nook, about 12' X 12, with 2 exterior walls. The floor is always super cold in the winter. The room is built over a VERY low crawl space that has vitrually no access to it. Even if you could get access, there would only be about 8" of access...the distance between the bottom of the floor joists and the concrete slab that covers the house's old (no longer used) cistern.
Now...the rest of the house is over an unfinished basement, which I insulated with a vapor barrier and 2" polystyrene and it made a BIG difference in my heating bills. Since I can't get to the inside of the crawl (without a jackhammer)...I was thinking about excavating a trench around the crawl space, wrapping it with a vapor barrier and installing polystyrene up to the bottom of the siding. I have 2 questions though:
1. How can I protect the polystyrene from getting hammered by the weedeater?
2. How can I protect against carpenter ants or even termites using the polystyrene for nesting?
Ohhh...BTW the water lines for my garage run through this crawl...so it's garage related. Well...maybe not....but any help or advice would be very much appreciated!
Phil
Phil
