Exterior lights install location
biggziff
Upstate NY
Is there a rule of thumb for where lights should be mounted (either side of overhead door) ? Height and distance from door jambs?
I've got about 6' on either side of my 14' wide door and am trying to figure where the most appropriate place for the lights should be. I'm not good at the aesthetic portion of this.
thanks
Toomanytools?
Washington
I have seen many a placement most likely 2 lights each side of door at about header height. Some placed at center of door overhead. "Google" pole barn exterior lights (images) and you get a lot of ideas.
Lelandwelds
Central Texas
I am a bit curious about the size and intended use of these lights. Are these motion sensing to scare thieves? Little bitty 20 watt downlighters so no one backs into the building? Big old honkers because you cant get enough midnight basketball?
Lighting the outside is something I hadnt thought about. Whats going on outside?
biggziff
Upstate NY
These will be sconce style lights mounted to the front wall on either side of the 14' overhead door. They'll be there more for presentation than anything else as I'll have a couple high powered LED security lights mounted high on the building to provide work light, etc.
My question is more about horizontal positioning. I see lots of pics online of lights mounted about in the middle of the walls on either side of the garage door, but most don't have 5-6' walls on either side of the door. My contractor wants to put the lights about 6" from the door jambs and I'm not sure that's going to look right. I **** at this part of the design stuff.
roscoe2000
Seat Pleasant Md
I have standard size garage doors so I mounted mines using the door header height as a reference as I was more interested in aesthetics' Using three lights for two door, these are just for knocking down the shadows. These have low wattage LED bulbs. With a third (motion) light high up at the roof apex for security
Lelandwelds
Central Texas
My rule of thumb is to draw lines at one thirds and two thirds of both vertical and horizontal. I try to place near where lines cross. The "Golden Rectangle" is a classical answer.
I am a rookie at aesthetics. I find some of the "that's the way we always do it" assumptions baffling.
biggziff
Upstate NY
Thanks!
yeldogt
I'm not sure anything is going to look correct with a 14' door .. that's not a human scale opening. Maybe a picture.
A typical downlight sconce would be at 5' an open at 5.5 and a larger lateen style needs the top to be at 6.
The 14' throws this all off .
75gmck25
Alexandria, VA
I have a brick garage with a single 8' wide door, and my plan is a gooseneck barn light centered above the door. It works for a small garage, but might look too small for a 14' wide door.
Bruce
cybrdyke
USA
No.
If you were to do it correctly, there would be plan for how much area you wanted the light to cover and how much illumination you wanted there to be.
Once you have those two pieces of information, you would be able to look for fixtures that will fulfill those needs AND that suits your style preference. The fixture manufacturer provides information on the mounting height via photometric reports to tell you the optimal mounting height.
Other than that, you're going to be playing a guessing game.
Good luck,
CD
Lelandwelds
Central Texas
I'm not sure anything is going to look correct with a 14' door .. that's not a human scale opening. .
No... you're going to be playing a guessing game.
Good luck,
CD
Oh, come on. He's not planning lighting for next years Superbowl. He's marking the sides of an existing door that may be a bit dominating for the space. He probably is trying to define or draw the eye away from the attention demanding door. ( A trompe l'oeil paint job probably isnt one of his skills. It isnt one of mine. )( I KNOW he is more fond of the big beautiful door than the two lights hanging on either side.
When I am making soup, I do not say " you must define your intended potato to carrot ratio before I can begin." When I build a new flat bed and it is time to add clearance lights, I dont say" email the mfg for the photometric report so first the light coverage can be determined".
No, the generally accepted method for small jobs is " that looks about right". Nothing would every get accomplished. The "1/2 and 2/3" suggestion is a common one for improving action photography. Pi and "golden rectangle" are based on observing nature and go back thousands of years. Pretty good rule of thumbs.
biggziff
Upstate NY
Thanks
We used the Golden Ratio and taped up some mock up lights made from cardboard. Looks perfect!
Funny thing is...my wife and I first stood out there and just "by-eye'd" it and when I measured the location was almost identical. Funny how that works.
Lelandwelds
Central Texas
Yes, I agree. I still think it is much smarter (and cheaper) to ask around a bit when tackling a foreign idea on new turf. It is hard to know what you dont know.
biggziff
Upstate NY
\ It is hard to know what you dont know.
I think learning this lesson some years back has been the single biggest advantage I've gotten in life. Not worrying about what someone else thinks about what I don't know has made me a much wiser person!
Thanks again.
whisperinsam33
Here's the clue:
"These will be sconce style lights mounted to the front wall on either side of the 14' overhead door. They'll be there more for presentation than anything else"
Here's the answer:
Ask your wife. Only she knows where "presentation" fixtures should be positioned.
Lelandwelds
Central Texas
Thanks
We used the Golden Ratio and taped up some mock up lights. Looks perfect!
Here's the answer:
Lol. Lots of people here admit what we never admit aloud to anyone. The wife wears the pants because she decides if and when they come off.
biggziff
Upstate NY
Here's the clue:
Here's the answer:
I'm no dummy...she was asked long before any of you guys!
