That's slick!Have 5 minisplits installed. Used Airex pro system for the linesets, control cables and electric. Expensive but looks neat, seals out rain and provides a vinyl wrap to protect the lines going into the outside unit from the weather and sun. Once installed, I shot a small amount of non expanding foam into the bundle from the house interior (basement) for an air/rodent seal, could be done from the outside. Used the largest diameter size. Picked up a couple on Ebay, prices vary considerable from dealers.
Airex Pro-System Kit™ | Airex Manufacturing Inc
TGS Airex Pro-System Kit TRS Airex Pro-Systrem Kit TSS Airex Pro-System Kit PRODUCT SUMMARY The AIREX PRO-SYSTEM KIT™ is a 2-in-1 system used to gasket seal HVACR piping penetrating through exterior walls from air leakage (AIREX TITAN OUTLET™) and to protect pipe insulation from outdoor weather...airexmfg.com
Initially I thought really expensive for a piece of composite plastic. Still think expensive but it solves a few issues. Easy to install, provides a rain proof seal for all lines entering the home, looks good, a UV resistant vinyl wrap is provided to cover all the lines (if you bundle the lineset and the electric/control lines) and seals them rain with a little effort, provides a decent seal against my houses sheathing.That's slick!
With the Airex product, the only fault I give it is you need to order the largest diameter boot size or else you will have a tough time getting all lines to easily go through the rubber boot especially if you lineset insulation is on the thick side.Used the largest diameter size
I only installed one mini but I used the same hole.Do most folks bring the drain line out through one large penetration, or is it better to have a dedicated penetration for the 3/4" PVC?
Is there some sort of fancy cover to use on the three-quarter inch PVC or just a hole and some sealant?I have my line sets and wiring in its each location (pitched downward) and another for the drain from both my units, pitched down. Both the drains go into 3/4 PVC exits the garage.
Sealant only...I did a clean 7/8in dia hole and sealant around it. I also have a screen on the end to prevent bugs etc from going into the line. I cant take a pic if needed.Is there some sort of fancy cover to use on the three-quarter inch PVC or just a hole and some sealant?
I suspect most installations use the same hole, but what's the right thing depends on the details of the installation. A separate route can make it easier to make sure it's got good slope, but requires more holes in the building, and makes the inside installation more complicated.Do most folks bring the drain line out through one large penetration, or is it better to have a dedicated penetration for the 3/4" PVC?
Same here but your not only drying the air but all the materials in the building. Once you have the minisplit on for a while the amount of water decreases.I am still shocked by the amount of water the unit pull out of the air!
Is there a cap I can use to block the hole to allow water to drain but not let anything enter from outside? Like a check valve maybe? Idk.
I thought about a piece of rubber like from an inner tube and using the urethane caulk to secure to the top edge of the pvc. Basically making a flap.
