CarCrazyRDM
I'm planning to install some exterior outlets on my newly built detached garage soon, possibly this weekend, and I'm curious as to what the best/preferred method is. The two options I've come across are to cut a hole the size of a single gang box in the side of the building and then mount the box like you would any other, having kind of a flush mount weather rated outlet cover on the outside of the wall. The other option seems to be to mount the gang box facing inside the building and then only drill a 1/2" or maybe 3/4" hole through the back of the box and exterior wall and mount an entire enclosed box on the outside of the building.
Is it just a matter or whether you want to have a "flush mount" electrical outlet or one that protrudes 3" from the side of the structure? I know I would prefer the flush mount look but part of me also thinks only drilling a hole in the side of the building, as opposed to a big square, allows less opportunity for leaks, sealing issues, etc. Is one better than the other or just personal preference? And/or are there other options I am not considering?
Also, if it matters to your suggestion, I have hardiplank on the side of my garage.
Thanks for any input.
