exterior recessed box
Paulski
Hey,
I upgrading my meter panel (mounted outside, recessed in to the wall) and am adding a NEMA 14-50 receptacle in the wall below it, I want to make sure I got the right stuff:
4" x 2 1/8" square box mounted to the stud, offset so it will be flush with the stucco
https://www.homedepot.com/p/2-Device-Drawn-Switch-Electrical-Box-683SP/202056186
Running 6/3 with ground NM-B wire to the 14-50 receptacle
https://www.homedepot.com/p/Leviton...w-Single-Outlet-Black-R10-00279-S00/300324414
Than stucco around the box and add a weatherproof cover
https://www.homedepot.com/p/Hubbell...sal-Flip-Lid-Device-Covers-MX2150SB/202266489
My main concern is am I using the right size box? Also, is there a deeper box than 2 1/8" to give more room to for the wires?
Norcal
I would use a 4 square box and ring, hate those boxes the OP linked to almost as much as handy boxes.
P
Paulski
Zeke - the only 4S deep boxes I can find has the threaded tabs on the corners, the weatherproof cover/14-50 holes wouldn't line up to that, I can fab something up or take a walk around HD to see if there are adapter plates unless you know a better way?
Bretny/Mmia23 - I am concerned about water leakage and properly papering/flashing around everything, the old meter box was recessed into the wall and there are 2 other receptacles on the exterior of the house that have been built into the stucco since the 1950s and it doesn't seem to have had any issues. Any suggestion on how to keep the water out?
Zeke
That is the difference between a handy box and a standard square. You need a cover anyway for the recep and the in-use cover so you have screw holes where you need them.
Bert_
NW Iowa
4" square with mud ring is the pro way. Those boxes in the first post scream handy man.
4"square boxes come in 1 1/2 and 2 1/8. If that's not deep enough use the 1 1/2 and add an 1 1/2 extension ring.
You select a mud ring to match the thickness of the stucco. The 4" box is set flush with the stud and the mud ring will be flush with the finished surface.
P
Paulski
Is the enclosure recessed into the wall or surface mounted?
It makes a difference, other questions may follow which will also make a difference in how you write it up.
The enclosure will be recessed into the wall, mounted to a stud. Right now I'm planning on a 4" box with a 1 1/4" mud ring and a weatherproof cover
Bretny
Dutchess county NY
How to keep water out...surface mount it.
P
Paulski
What about the hole the wires goes through to get inside the surface mount box, how would i keep water from getting into that? Or the screw holes needed to mount the box?
u2slow
BC
Sealant. Duct seal, polyurethane-based stuff (i.e. sikaflex), etc. I always put a drain hole in outdoor installations.
As you say, a 4x4x2-1/8" box is quite small.... I'd probably use something like this instead:
https://www.homedepot.com/p/Eaton-5...Temporary-RV-Power-Outlet-Box-CHU1S/100565603
dscheidt
3", 3 1/2 and 4" boxes are available as well. Probalby not at the borg, but they're made.
