External Chamfer/Deburring tools.
2ndGearRubber
Pittsburgh
Occasionally for problems unavoidable and otherwise, I'll have nicked up threads at the very end of a bolt, or mushrooming when I beat something out with an air hammer. Usually my go-to are thread chasing dies, split dies, and thread files - but I was thinking creating a smoother starting taper when doing such repairs to hardware would be beneficial. I would be using this almost exclusively on steel hardware for automotive applications.
What are you using? Amazon has lots of no-name options, some with blades, others with just cut-outs. They mostly all appear drill powered, which is fine.
charbar
Midwest
I assume you're talking about the cone shaped things? I don't have one but always thought I would buy one sometime. As long as they aren't made of butter I think the would be an awesome tool.
I usually just hit the boogered up area with the angle grinder quick and go on with my day.
rlitman
Long Island
The ones I've seen don't look like they'd be good on steel. I usually use a file over the edge, or a triangle fine inside the threads, but a stationary belt sander is the quick way to go.
HenryAZ
MEMBER EMERITUS
South Congress AZ
For pipes/tubes, I use this Shaviv 29147 external chamfering tool. It is good up to ~1" OD material. For threaded stuff, a light, single revolution against a stationary belt sander at 45* works very well and quickly. Just twirl the screw against the belt. The contact with the belt is so light I typically do this holding the screw in my fingers up above the table. For very small/short stuff I hold it with locking pliers. I have never had a threaded piece fail to enter and screw into its mating female piece when done this way.
2ndGearRubber
Pittsburgh
The cone style is what I'm looking for. Belt sander would be nice, but sometimes things cannot be removed. Thanks for the recommendation HenryAZ, Israel made seems good.
signcrafter
I bought one of the cone type chamfer tools that go in a drill last year from napa. Was in one of their monthly sales that I'm a sucker for. Paid 45 or so bucks if I remember right. I've only used it a couple times but it does what it's made to do. I dont remember the brand but I can look when I get home.
