LifeLongWNYer
Hi to all. Was a frequent reader, but dropped off while I built my pole barn, now I'm back with questions.
I have a 100 amp panel in the building and have run conduit to two locations in which I am planning to put receptacles for a welder, which I don't yet own. Would "like" to run wire for short term use of a 110 VAC welder, with the possibility of converting it to handle IF I ever decide to get a larger one. Sooo... may I pull two stranded THHN conductors, a hot and a neutral, for the current 110 use, then, if/when I want to convert to 220, change the neutral to the other hot?
IF SO, should I pull in a black, or red, conductor for the neutral but wrap it with white tape at both ends, to satisfy my current usage, or should I pull in a white conductor for now, then if/when I convert to 220, tape it red?
( I understand that a ground wire is also needed. )
JBP
Rochester, NY
JBP
Rochester, NY
