Extra deep tip out trays
lynnbilodeau
Oklahoma
Finishing up a remodel of our master suite. Would like to install tip out trays on the sink drawer fronts at each vanity.
Opening is 29.75 wide and 4.25 high.
I have much more room than most between the drawer front and the front of the sink; just over five inches.
I would like a tray that takes advantage of the extra room. Ideally I am looking for something 28 inches wide, 3.75 to 4 inches high and at least 4 inches deep; preferably 4.5.
Anything like that available?
Thanks in advance.
PCustoms
VT
Have you considered making short drawers?
Watching as I'm about to finish the kitchen cabinets...
Dig Doug
We have a drawer front w/ 2 plastic U shape on the inside
wife stores scrubbys / sponges scrub brush etc in them
johnre
Portland, OR
I've made drawers almost that short (6"). You can get good quality Accuride 3800 slides at that length that fully extend; it's the shortest length they make. Look here:
If your sinks are round or oval you can probably accommodate the excess 1" slide length sticking out in the back. As a matter of fact, some cabinetmakers have contoured the drawer shape around the sink, taking advantage of more depth at the sides to maximize space utilization. If you did this, you could go to a more standard slide length.
Do be aware that any short aspect ratio drawer won't glide as easily as a deeper one; it will want to "rock" side-to-side when opening or closing it.
Another idea might be to make swing out drawers that are hinged at the outside; that would need a pretty stout hinge to take the drawer weight and not sag though. I would probably make my own with hardwood dowels.
  • Like
Reactions: Max
gahrajmahal
Cincinnati, Ohio
Like jar944 shows us, you should just build what you want either using the “tipping hinges” like on the shallower versions you mention or using drawer slides as mentioned. As far as what to make the drawer buckets from, using cardboard boxes find one that fits the space then go shopping in the plastic storage container isle of your big box store and select a sturdy version that has the correct rectangle footprint. Mount it to the face panel with some long L-brackets and cut the height to fit using your ultrasonic saw.
Or, do like the ancient craftsmen did when building a grain or produce storage cabinet and fold up some tin and solder the corners together to make your drawer shape.
larry_g
oregon
Just remember the old saying "**** acuminates to fill the space available." There is **** in this house that went into the drawers 15 years ago that has not seen the light of day since.
lg
no neat sig line
L
lynnbilodeau
Oklahoma
I purchased these cabinets (along with a few more) from a Vo Tech in a Public Surplus Auction.
They were being used as general purpose cabinets, so they all had functional top drawers. I flipped one over, reversed the drawer guides, cut off the toe kick area (which was now on top) made a shelf and a top for it, and we placed it in the middle on top of the other cabinets for towel storage. We went from a 6 foot vanity to a 110 inch vanity area. Even though we gained a LOT of storage from our previous set up, I wanted to utilize the area behind the two drawer fronts where the sinks are. The sinks are closer to the wall than standard (by design) so I had extra room. That is why I asked about an extra deep tilt out set up. Nothing that I could find, so....decided on U shaped drawers.
I searched for something pre-made, but nothing showed up. Did not want to purchase new drawer boxes. These boxes are high quality hard rock maple all dove tailed, so decided to modify them.
Had some left over gray PVC sheet from a project 30 years ago. This is why I don’t throw good scraps away. Cut up the old drawers, and fitted the PVC to go right around the sinks. Used oak blocks to hold the PVC in place. The drawer bottoms were floating, so I glued them in the back corners for extra stiffness.
All worked out well. I included a pic of the tilt out trays that came out of our old vanity set up. You can see how much more storage we gained for little things.
I realize that the "right" way to do this would have been laminating wood into the shape I needed, cutting a "U" groove to fit over the bottom shelf and glue it all up. But, I had this material sitting around. None of this shows when the drawers are closed. It is plenty strong the way it is.
We are going to use one of the left over cabinets to make a “head knocker” for the water closet; even more storage.
L
lynnbilodeau
Oklahoma
Pics of the finished vanity area.
Getting new carpet next week.
