garfunkle24
I see a lot of repeat questions on here regarding broken bolts, extractors etc. For the benefit of the newer guys I thought I'd post up pictures of the various types of extractors (the ones I have any way).
By doing this it will it least help guys know what their choices are and will hopefully create a forum for people's opinions of the various types.
Just to be clear; I hate all extractors. I just hate some less than others.
First and foremost, this is the best extractor known to mankind:
If that doesn't work, most likely you're screwed and none of the following will work either:
Left-hand drill bits:
If you're very lucky and the screw/bolt isn't 'stuck' you may get it out with just a LH drill bit. Most of the extractors below require a hole to be drilled anyway. Drill it backwards and you might just get lucky! These are Mac cobalt bits, but you have a ton of choices in this area.
Long spiral:
My most hated variety of extractor. Note the gaps in the set....they're there for a reason....These ones are Hanson/Irwin.
Short spiral:
These aren't too bad IMHO. These ones are labelled Mac, but are made by a different OEM and sold through Mac, Snap-on etc
Square taper:
These are joint personal favourites, along with my Rennsteig "cross-taper type" (I just made that term up). These are Proto, but I have seen them labelled as Armstrong and others. Snap-on also makes some similar ones with a twist in the end and they work equally well IMHO.
Cross taper:
These are made by Rennsteig and I've had very good luck with them. Unlike the Protos above, these work in both directions.
Screw-type:
I just recently got these from Wurth. As I haven't used them yet I can't comment on their functionality.
Spline-type:
These are middle-of-the-road for me, functionality wise. I don't use the extractors much anymore, but the drill guides from the set get a lot of use. These are sold as Blue-Point through Snap-on. I'm not sure if they're sold through anyone else.
Hex extractors:
These are basically a tapered (beat it in) type extractor for stripped out hex (allen) head screws/bolts. They have worked great for me.
Screw or "Grab-it" type extractors:
These are sold through many common hardware stores; Canadian Tire, Sears, HD, Lowes etc. I bought them when I was stuck on the road somewhere. Just needed them for some woodscrews with stripped phillips heads. Not sure how well they work on anything beyond that.
External extractors:
These ones are Snap-ons but I've also seen Mac, Proto, Lisle etc. Unlike some re-labelled stuff, I know these aren't all created equal. My Snap-ons have been good, YMMV. Of course on external applications, you have a lot more options (vise-grips, welder, stud puller) before you need an extractor.
External extractors (2):
I just found another type of external extractor from Lisle, part#19250:
http://www.lislecorp.com/divisions/products/?product=67
I have no experience with these.
I don't keep up with external extractors so much as a I rarely need them and when I do, they typically work very well.
Well guys, that's all the extractors I have lying around here. Anybody who has pics of different types, please post them up for all to see.
Long spiral:
Short spiral:
Square taper:
Cross taper:
Screw-type:
Spline-type:
Hex extractors:
