Fabrication dilemma (HD engine stand)
DavesGarage
Phoenix, AZ
I am working on a heavy duty engine stand and Ive come to a point that is holding me up. I am not a fabricator by any means but Ive dabbled in it. My issue is I am trying to line up a 3.5" piece of round pipe to pass through (2) 4" square uprights that are 42" apart. The 3.5" piece will be cut down to 4.5" long to hold 2 bearings and a shaft in each 4" upright, I am trying to get that shaft lined up to the other side of the stand so that theres no binding when rotating the engine.
I have several pictures to show, if I can figure out how to share them. Last time I shared was with photobucket....
JJohns3WG
Paso Robles, CA
I'm not quite sure what your trying to do but it loos like if you started with a longer piece of pipe you could weld the ends in place then cut out the center. The other option would be to cut the ends to size then use a piece of angle iron to keep them aligned.
bullnerd
Jersey
Angle iron?
Laser?
String?
Threaded rod and some fancy washers...otherwise known as wooden plugs?
Base looks sweet so far.
gearhead1
NC
That was my first thought also, leave the square tube long then cut out the center.
gorilla
Two ideas for you, redesign your bearing housings to bolt on so that you have some adjustment for alignment. If you must weld use bearings on one side and a bushing on the other If you give the bushing a **** in a shirtsleeve fit it will support the weight and alignment wont matter.
matt_i
Your lineup bar could be something like a piece of 3/4" cold rolled (1018 solid round)
If you had a lathe you could turn some bushings to center the 3/4" on the larger ID.
If you park the stand in a place and leave it there you can use a level to get pretty close alignment vs. the stand.
Gorilla's idea of making one or both bearings in a bolted-in housing with oversized clearance holes is a good one. Then you can shim, adjust, and the rotation will find itself with one side loosened up. Then tighten the bolts and leave them that way.
I thought I saw a pillow block (?) those are spherically aligning, if a 2 bolt pillow block it has some slotting to slide left/right. The up/down can be aligned with spacer blocks/shims.
Just some general ideas that might help.
