Fabricators, Which saw would you choose?
Scotts Elle
I do a bit of fabrication work on the side building displays for industrial equipment so I cut everything from aluminum, brass, copper to stainless and mild steel. I have been using a chop saw for hard metals and a standard miter saw for aluminum. Its time for an upgrade as I am getting busier and the quality of the cut needs to improve... I am also sick of getting showered in sparks and chips.
I am looking at basic cold saws for the $2500 to $3000 mark but I am restricted to 2.5" square stock. Also, anything bigger and I need 3 phase 400volt. I work out of my garage... 220VAC is as good as it gets. I prefer the cold saw as the cut quality and accuracy is better but now I am restricted to 2.5" stock.
The other option is a horizontal band saw. They have a much larger capacity for the very few times I would cut 6" box tubing or 80/20 extrusions but the cut quality is not as good as the cold saw. The accuracy is not as great either (or so I'm told). They are much cheaper. I can get a decent saw for around $2000.
What do you guys use? Why? Any advantages to one vs the other?
Thanks.
Scotty
Strouty
Southern Maine
You are way overspending, mine was not more than $500 and will cut 4" on a 45 angle if I am not mistaken. I will look for some specs.
madjack
black hills of south dakota
Problem with abrasive saws is the steel work hardens at the point of the cut. The abrasive saw that was in my shop and was what I started with, is now unused in a storage room. Never use it anymore since I bought a portable Milwaukee 6370-21 metal cut circular saw for under $300. A table type vertical bandsaw will do most anything needed if it has a deep enough throat and a miter gauge. A commercial grade drop saw is a great tool too but has limitations in that making small material cut are nearly impossible. I'm lucky in that I've got room for all of them in the shop. If I could only have one, it would be the Milwaukee with a saw guide
Strouty
Southern Maine
The saw I showed him was not an abrasive, it was a true cold cut with a saw blade. Abrasive saws have there place, but the cold cut saws truly make a beautiful cut. I can cut a piece of pipe and it will be flat and smooth. Plush the material stays pretty cool to the touch.
alex71
SE Florida
That Milwaukee is not a cold saw. This is a cold saw:
bB58XzQKx4-IVd9HKZKsRGMi0Ux_AC4SaH5WdoCyd76RG5FG-KI9zl4Gqn9OGSD7FNhubO9dAKRbm5k2SoTot23KoyCX0tJRDamp8HuZDzrdbvoJqeP-Hq6H4yh6dYVcDVc1VPXELb1FFhZhTkXTc2woLtQVKUOFaPW_TIeE_SHAOLpjEPUV
Scotts Elle
Thanks for the replies. I am referring to a "wet" cold saw. The links being posted make horrible cuts, spray sparks and chips all over, and are not very repeatable in cut accuracy.
With either saw, I definitely want a coolant system.
Either isn't cheap but the work I do can't look cheap.
