I need to insulate the finished ceiling of my 24 x 26 detached garage with either faced or un-faced insulation (do not like blown insulation). I have easy access to the attic therefore I will just lay the rolled batts between the joists. I have a ridge vent however think I need to add a couple more soffit vents as I only have two on each side (2' overhang).
I occasional heat the garage with a space heater in the winter months however my main reason for insulating is to block the summer heat transfer from roof to garage (below). Should I use faced or un-faced insulation? Does it matter? Is R-13 or R-19 sufficient? Your thoughts on more soffit vents? Any advice is appreciated.
