Fahrenheat FUH724 electrical run help needed
ineedagarage
Hello
I have a Fahrenheat FUH724 that am going to install using 8/2 wire with a 40 amp breaker. Also using a twist lock receptical and plug. The run of wire will be 50ft will this set up be ok?
Thanks
nehog
Jaffrey, NH
Should be OK. That heater draws 32 amps (as per the maker) so it will squeak by on a 40 amp breaker.
