Ststephen7
Hey guys,
I got a Famco 612, and it looks and works great.
However... the only part missing is the part that would push on a handle to turn it off when done cutting.
Is anyone who has one willing to reply with a picture of that part so I make a replacement?
I did try to make my own, and as you can (might) see from the pictures, the rod has lots of play in it, and in all of my attempts it wants to kick to the inside or outside, and wedges itself so it won't turn off the saw.
I guess I could redo the whole switch set up, and I'd rather do the simplest thing.
I also have an issue with the cylinder that controls the downfeed. I'm guessing it's low on fluid... Here is what it does: When I lift the saw all the way and allow it to start dropping the cylinder does not do anything until the saw drops quite a ways... about where a 4" piece of stock would be in the vise.
Then, the control knob only works at the far end of the range, either stopping the fall, or allowing it to lower either pretty fast or way too fast...
Do I need more fluid? And... since I don't know what's currently in it should I empty it and refill with... what?
Thanks,
Steve
Thanks,
Steve
