Roberts210
Found this rusty Famco press at a local machinery seller's outdoor yard for $100. It was missing the brake, daisy wheel, the racheting arm and rachet pawl, and had been knocked over, breaking some of the handles on the ship's wheel.
First thing I did was clean the press all up, remove the rust and prime and paint it with Ford tractor paint.
Famco is still in business, so I asked what a new brake, daisy wheel, racheting arm and rachet pawl would cost. Got a reply back--more than a thousand bucks--a lot more. To heck with that!!
Then I started on making the missing parts. I made a brake out of an old bronze door knob. Worked great.
Then I went to work fabricating the ratcheting arm. I took two pieces of 3/4" steel and welded them together and had a machine shop do the drilling for the holes. For the "cave" for the end of the pawl I drilled a hole and cut the cave out with my old Delta W&M bandsaw, and welded side pieces on the cave. A friend on the owwm website gave me the daisy wheel for shipping cost. For an extension on the ratchet arm I used a 3 ft. long meat hook from a slaughtering plant. It is some kind of strong steel--I can't bend it even when I hang all my weight on it--which makes sense since cows hung on it at one time.
For the pawl I took a big old grade 5 bolt and started cutting and grinding on it, careful never to get it too hot. You can see my crude wooden pattern next to it--hey, I never said I was a pattern-maker!
Works real good.
Works real good.
