Fan wiring diagram
keith5064
I'm not much on reading wiring diagrams, could someone interpret this for me?uploadfromtaptalk1464922103918.jpguploadfromtaptalk1464922199309.jpg I will be using this for a 115v application, which leads for hot and which leads for nuetral..thanks
Sent from my SM-G930R4 using Tapatalk
matt_i
You want low voltage (120vac) so use the diagram at left. Your hot and neutral wires connect to 1, and 4, respectively. But you must also jumper the other wires or terminals (hot, 1,3,8)...(neutral, 4) and (2,J,5) using wire nuts, as indicated in the schematic. It also explains how to reverse the rotation, which would be (hot, 1, 3, 5)...(neutral, 4)...and (2, J, 8)
K
keith5064
That makes sense! Thank you!
