Fastener size for steps to outdoor deck
tominboise
I am installing three replacement stair treads at my cabin. These stairs go from ground level to the porch. One set has two steps, and one set has one step. The stringers are made from round logs cut in half lengthwise so it is half round, half flat.
The stair tread itself is 4 X 10 pressure treated timber, 48" long. The tread will sit on 1-1/2 X 1-1/2 angle lagged to the stringers. There are 4 lags going to the stringer and 3 lags going up into the bottom of the tread, on each angle. I made the angles 9" long and drilled all the holes 17/64". My two choices for fasteners are #10 X 2-1/2" (Simpson SD) or 1/4" X 3" (Simpson SDS).
The 1/4" seem to be the logical choice, but maybe overkill and the #10 are fine.
Any opinions?
PCustoms
VT
Either should be fine, I'd lean towards 1/4 in that big a timber.
More important is the screw holding this all to the stringer, and how the stringer is made
mike93lx
Richmond, VA
You're worried about overkill while using a 4x10 tread?
I don't think screw selection will matter much beyond one that is properly coated for PT
