Fasteners for vibration?
SarcasticDwarf
North Dakota
I *may* be overthinking this!
I am installing an air filter and some other stuff from the garage ceiling, mostly using threaded rod and strut. This means that the weight of the devices is being carried by the nuts, either directly or behind a washer.
Should I be doing anything to prevent the nuts from backing off due to vibration (I really don't want a 60 pound device dropping on me or the car)? If so, what? The extreme seems like it would be either a castle nut with cotter pin or locktite, while something simpler would be K-nuts.
rlitman
Long Island
Pairs of nuts locked against each other would be good. Or nyloc nuts. Or drill and cotter pin (I don't think you'd need to actually use a castle nut for this). Or just blue loctite.
MoonRise
Lock nuts (aka Nylock or similar) or blue Loctite should be plenty and relatively simple/easy and not too expensive.
lakeroadster
Central Colorado
You're application is no different than any other bolted joint.
What you use depends on the design of the joint. Spiral or tooth lock washers are what is typically used.
You could also use some Locktite thread locker.
SGKent
Citrus Heights CA
double nut and loctite would give you that piece of mind. Make sure your rods are designed for that load and not some really cheap ones that might crack.
vavet
Ashland, VA
I'd prefer a double nut over an elastic-insert nut.
Is the nut near the end of the threaded rod or several turns in? If it's near the end, then a stover nut might be appropriate but you don't want to be turning that too far in or it will lose some of it's locking ability.
matt_i
I have installed threaded rods in a plant with blue and red loctite. Both work well, but always good to jam the hex nut against a square washer and also have it theaded into a spring-nut/strut-nut.
Fix Until Broke
SE Wisconsin
Double nut and mark them and put a bright contrasting colored line across the face of the nuts. Any time you glance at them, the line should be lined up. If they ever separate, you get some visual warning before gravity takes over.
cadunkle
Doublt nut, plus loctite or tack it. If you have something hanging that vibrates I would use rubber washers or similar to dampen vibration transmission and lessen chance of fatigue of hardware/hangers/etc.
MFolks
Springfield Mo.
242 BLUE Loctite for joints you need to take apart.Only 222 RED Loctite for joints that are almost permanant,but will come apart after high heat is applied(sometimes 500F).
SarcasticDwarf
North Dakota
Leaflessshadetree
Don't ask.
Actually this is usually different than most bolted joints. With just the weight hanging on rods there isn't any "bolt stretch" to hold torque. I'd put nuts on both sides of the strut and bracket Double nut the top and bottom. I'd even consider putting in spacers (1-2" tall) to allow "stretch" of the rod.
wssix99
Chicago, IL
Do you have a safe way to attach the threaded rod to the ceiling?
I came home one day to find our HVAC contractor doing this and putting the threaded rod through the bottom chord of a wooden floor truss...
After much spirited debate and insults to my lineage, I was able to move them off to a cable system to suspend the strut from the top chord. (Fortunately, we were new construction and my truss designer was able to step in and inform the HVAC contractor that the vibrations and point loads would bring the floor down.)
atenbilly
Fort Worth, Texas
I work in industry, we hang things using this method on a regular basis. Double nutting is the way to go, for both the security you seek and ease of application.
Can one ever really have "too many tools"
