Favorite 3" 3/8 drive extension?
MrGiggles
My GW extensions have knurling on the shaft. They're my favorite as far as chrome goes.
I've had good luck with the Pittsburg Pro Cr-mo impact wobble extensions. They're dirt cheap too.
back2class
IMHO there are FOUR kinds
1) Cheap chinese or other junk that come with throw away socket sets.
2) Wobble..HATE them for any reason other then when wobble is needed.
3) Ones with knurling..on top is nicest, but not matter really
4) Everything else. Craftsman, Duralast, Cornwell, Husky, Proto, Harbor Freight and so on.
Really, they are all the same and every single one from any half way decent quality is a good as the next. Really, any 3" extension good enough to have any name brand on it is fine. Just pick if you want knurled or unknurled....any brand. Does not matter. The fastener is going to break LONG before the the extension unless you are doing something like a 1" socket on a grade 8 bolt with a pipe on a 3/8 breaker bar.
Dave455
Sussex, England
Get one from the same maker as your sockets and handles! It will generally fit better, sockets will be held better, and so on!
Failing that, get one from the same country of origin, chances are they will be made to the same standards!
JUNK-MAN
PA
My one Snap on extension is a newer one, 3" fixed with knurled patch. Perfect for most jobs.
D
d.mcfarland
Western PA
Well the features do matter in many instances. I'm not talking strength of the metal, more about the features of the extension. The fit of the male and female ends being a big one right off the bat.
jkesselr
I really like my old P&C extensions. They neck down over the length and then become larger right at the male and female drive ends. I don't know how many times I have been able to get squared up on a fastener because that slight relief allowed me to clear some other component that was in the way.
shockwave
Marietta,ga
Snap on is my go to seem to fit tighter that others and ball retention is stronger
Older matco seem to be loose
californiaHank
I use a short (1", Snap-on FX1) extension a lot. It's just long enough to give you some 'knuckle room' when you choke up the ratchet handle to spin the socket with your fingers. I use a 3" a often, too, but there are a lot of places where the real short one will fit, and the 3" won't.
Local
Fallbrook,ca
After growing up using Craftsman and finally using an extension with knurling I'm will never go back.
lightning02
same here. i could never understand why they couldn't add that one feature. even the cheap china made ones at the dollar store could but USA cman couldn't lol
bsg1
so cal
i have Snap-on extensions, Plomb and others from early time periods to current production Snap-on and they are all gtg. for general use on my home truck repairs i use Snap-on FXK extensions and if i could only have one it would be the FXK3. i have the FXKL6A locking extension for lost socket prevention.
Cope
Houston, TX
For some reason, Snap-on never made a 3" 1/4" drive extension until recently, and only knurled. being **** about not having a 3" I bought one, and it is my go to 1/4".
bsg1
so cal
not being able to find one out in the wild, i am going to pick one up from ebay. my OCD refuses to believe that i don't need the 3" knurled extension that until now i've lived without. i've picked up all the other knurled 1/4" drive extensions at the swap meet but would like to complete the set just because.
