JackOfDiamonds
I'm a big fan of drywall. It's cheap, relatively fire safe, infinitely patchable, and you can hang things anywhere on it. They key for a garage drywall is not to be sentimental about it and consider it an expendable surface to be consumed.
The problem with drywall anchors is they aren't consistent. You can have 5 drywall anchors that look like they are the same, but some of them work great and some of them work like not at all. Or you find one you like, go try to buy more of the same thing, and can't find it and get something else that isn't as good.
I have pretty good luck with the EZ Ancor drywall anchors from home depot. They are strong and they are flush so you can easily patch over them, but at about $0.50 each, I'm wondering if there's not a cheaper or better option.
I tend to not like toggle bolts, even though they are strong, because you have to drill a really big hole, and they are fiddly and hard to get them tight and they fall off inside the wall. But I know that SOME toggle bolts work great but it depends on the specific product.
