Favorite iron worker's pliers?
Ton ton
Page County,VA
What do y'all use for ironworker pliers? They're heavier duty than regular linesman pliers and they have a hook bend in the one handle. What I am really craving is something that cuts wire easily. My knipex linesman plier wire cutters is getting a bit dull.
roofdweller49
My only experience is with a real beat up pair of channel lock ironworker pliers. Still a pleasure to use, and still cut well after being used for god knows how long. The nose is great for tightening wire. Klein also has a few nice ones
T
Ton ton
Page County,VA
Thank you for the quick response.
neophyte
Pennsylvannia
Is this for rebar tying ?
In some places, concreter’s nippers are used instead of pliers for tying off rebar, and the nippers are usually available in longer lengths than typical ironworker’s pliers, which should increase leverage, and ease of cutting.
Knipex makes Chrome Plated nippers, which may increase durability a bit, but I don’t know how much it would help.
I don’t think anyone has been making replacement blade nippers or pliers for decades, outside of small ones.
I think nowadays, you’re just meant to purchase a new pair of pliers when the cutters get dull.
Depending on how quickly the cutters dull, you might try purchasing a bunch of different brands, to see if any really are that much more durable.
Crescent manufactures two separate “linesman” pliers using compound leverage, but neither have the handle foot, and I don’t know that either would be more durable.
u2slow
BC
The Klein's I'm used to are smaller headed that the sparky ones, and spring loaded.
carmantl
You have to pull on tie wire to make a good tight tie. The bent handle won't slip out of your hand when doing so. Also above someone referenced #7 Klein's. They are light duty. Rodbusters prefer #9's. They are expensive but I'd get about 5 years out of a set back when I was rodbusting fulltime.
