Favorite low-tooth ratchet
Shane6377
I’ve recently been looking for a backup 3/8” ratchet to my everyday user. I don’t need anything special so I decided to check ebay for a good used ratchet. While browsing I noticed a lot of older low-tooth count ratchets at great prices.
I looked for older Snap On’s like F830 and F936 and Cornwell JR30’s and Proto 5249’s.
So what’s your favorite low-tooth ratchet? Let’s say 45 teeth or less.
Jason280
I have a couple MAC's that are really smooth, one is a hard handle and the other is a longer version.
bonneyman
Desert SW
Indestro pear-head 6272. Or a Moore Drop Forge Craftsman pear-head if you wanna go really old school.
Tenex
My Proto 5450 is the only low-tooth ratchet I own, but it's a real pleasure to use.
firworks
IL
Definitely grab a JR30 if you don't have one and see a deal. I've got a ton of ratchets but most of the time I grab an SR50 or JR30 because I just love the feel of them. Such nice ratchets to use.
Empty Pockets
Rural New York
I have an Indestro 6470 1/2" drive open gear ratchet. Maybe it's a sentimental favourite but my dad had one when I was a kid. I have it now
I use a Napa 3/8 inch American made (older) ratchet with quick release, and 2 older Snap on ratchets. One of the Snap on ratchets is especially short handled.
pilotmotor
The snap on 830 and 936's are nice ,I have many but the spring is too stiff. I weaken the spring or replace it with one from a pen then they are even better.
I prefer grip ratchets and the older mac are nice , but my favorite is a grip Armstrong.
jumbojak
Surry, VA
I have a 22 tooth proto. At least I think it's a proto. No knurling but all other features are the same.
Shane6377
I’ve thought about Armstrong too. I have a S-91 1/2” ratchet that is super smooth. The only thing I don’t like is the direction lever seems a little weak. That being said, the ratchet is probably 50+ years old and hasn’t broken so maybe they are stronger than they look.
1foxracing
Tuscarawas Co, Ohio
Cornwell
EnV2G83YzwbdgKume5P5F4hp-CFtGBRNo-_6-z4GTVLdvh5wm4VOrsISaDwznXa2X0HvRLc50J9bellamzD8RsFyiNLeYDc97sE0XbHkB5NIADl5xgA4MxTZTowhufozkBPNK_6h2bpS54h8Hjdg4jtYZ6uR8C_B8ImloAtPvtW74siBt5tZGGC5_L124PO0Ygeur3ZLDHGgz4CUBGgh9jdDXE3h1hRhx4pjZXfk5MsapjBRPim50EIiYKi7OOlTLz2LqFLM-chCcQIW_3mCPjrWk-clC046NrOEHbN7NvTVF0X5RwrTlC-hka_OOiLrWAZeHoVuEswfGGNWLdI-l0CK2Px2aAT6GmLCc1lAhzKCsT8nRgQttC-hNN8tmDmRQyysZ4FBVjBBftSnGSUdOiY8IvSTYJ1-K3GDdhf3SBNPcikNdWoVapE-Yn81kTfrKcnSMMqvR-mpZlJg8dxEANWQoJ8FNK0iuw2xV3JNSMsfJviOE-xxPiGz2HrDnQUp6NKwKnT1eV4HdCIPQf_gNY_s7wz2N9QwyrEMsTyeJm2ibFFlyRRSVOOvQm1AyEfEUL_xreJkVsqw8Rdcx4CfEuOVkHTNTukXVkakQ4NU=w956-h637-no
jsaw
Geneva, N.Y.
After using hight too5h count ratchets, I dont like to use low tooth count ratchets any more. The onlyreason I ever use a ratchet is if I cant fit a power tool in to where I am working. Chances are if I cant fit an air ratchet in, then iI probably dont hqve 3nough room to even swing a course tooth ratchet anyway
jshillin
PA
I agree with many of the guys here and go with the Cornwell. It definitely has a low tooth count, but super comfortable to hold and work with.
Fialaja
Another vote on the Armstrong s-91 I also have the Sk Frankenstein ratchet .thats cool but very low tooth count
ChevyEFI
Phoenix, AZ
Ko-Ken! 24T of buttery smoothness
Yep.
I have a 3757 palm ratchet.
I would try out the 3752N regular handle, or 3776N roto without hesitation.
Edit: those are all 45 tooth.
Though, I know my SK won't be breaking for decades.
lakelandcat
ditto, once you go with a 72 tooth you never go back, faster and catches a tooth in a tighter spot.
65k10
somewhere
While I like the low backdrag on my Proto 24t pearheads, out of the low-tooth ratchets I have, my favorite is the Williams S-52EHFA. Although to be fair, I like it despite being low tooth. My main reason for liking it is it's about 14" long which makes it handier than a 17" long flex head while still being long enough to give me decent leverage. If I could get this in length in a Dual 80 I would have my favorite ratchet of all time. However, since that ratchet doesn't exist and the 36 tooth mechanism usually doesn't pose a problem, I'm happy with my Williams.
DadsTools
Assuming the OP is looking at used rats as his post implies and not off-the-shelf new. I'd also assume we're looking at lower profile heads than the typical round head that for me never fell under the category of 'coarse' tooth....
I buy and sell used tools, including ratchets, and often encounter older ones. I've played around with using many of them. There's a few mentioned I've never encountered for some reason like the Armstrong or Williams. Of those I have, a few observations:
The Proto/Plomb/Penens design seem to have the least backdrag and once cleaned and lubed are among the smoothest I encountered. Some call them tic-tocs, I call them V pawls. However, I must also say that I've encountered an inordinate percentage of these that are just plain worn out, more so than other makes. I'd also include here the early 1950s Allenite, a Japan knock-off of the P/P/P tic-tocs, every bit as smooth and powerful. For me, though, the tooth counts are just too low.
The older Snap-ons I find almost always need some sort of work whether it be exceptional-quality lubrication, playing around with the spring, or in need of rebuilding. My Dad had some M series (military, but the mechs are the same as public sector product), and I was kind of surprised how many rebuild kits and older parts he had laying around for these until I started using the ones he gave me. Almost a situation that, because they are Snap-on, one finds one's self making excuses for them. One could debate as to why this is so, but I'm only reporting what I've experienced.
New Britain and its derivatives (not the Kilness, which is a round head, but the teardrop or pear style) seem to be solid ratchets, but to me always have excessive back drag. I'd lump Walden in with these too, which seem like a solid rat but the mech and finish just strike me as unrefined.
Craftsman--just don't like the CM philosophy behind any of their ratchet designs and executions. They are a 'use if I must' kind of thing.
The Duro/Indestro seem to be consistently nice in both the feel of the mechanism and the grip. They are kind of pedestrian to look at, but I give them high scores on what really matters. If I had to use a CT for a living, I'd lean heavily toward these, if it weren't for.....
The Cornwell coke bottles. There's something special about them. If I had to use one for a living and could only choose one alone, I'd have to tearfully say farewell to all those about which I find something endearing and go with these.
That's my read on it. Your mileage may vary.
pendragon1998
NE Georgia
I just bought a Wright 3430. 45 tooth low profile 3/8 ratchet. It looks nice, but I haven't used it yet. I must confess that I am a bit uncertain about the tooth count - I prefer a higher count.
davethorik
Norka, Ohio
I have an Indestro Super 3277 1/2 roundhead. IIRC 50 teeth and a very nice action. There is a ball detent on Tri-Wing selector (patented) and possibly the best and most positively engaging selector of any ratchet I own. However, it has the thin/flat handle design. Looks like a Craftsman RP and IS ABOUT as thick as a SK Artisan style handle, effectively merging the worst of both worlds into one ergonomic nightmare. Most of the Indestro round heads I see are knurled handle, and for good reason.
