Love the spammer. Reminds me of the wrenches my dad used to use hanging iron. Do you guys keep all your welding tools in your main box, or do you keep one by the welder for just welding tools?
My welding bench is an old 3 drawer roller box with a side cabinet. all welding related tools go in the roller.
Good grounds always seem to be the biggest issue when I weld:
The top is a 1/2" steel plate, and my magnet ground is semi permanently attached to it.
On the right side is a fold-up extension top with a small vise (the top is no longer fordable with the diagonal brace for the vice...), grounded to the 1/2" plate, and I have a heavy ground wire with a small clamp attached to the same bolt grounding the vise.
This allows me to weld dang near anything without having to worry about a ground...
Main "must haves": 4-1/2" mini grinders; one with a wire wheel, one with a grinding disk, or those overlapping sanding/grinding disks, and one with one of those 60 grit purple sanding disks.
Oh, and the 4 plex box/extension cord hung off the back side of the roller to plug the power tools into...
