feed-thru outdoor sub-panel selection
dcg9381
Austin, TX
So I'm needing an outdoor rated panel that has a feed-through lug configuration. Non-service entrance (neutral has to be able to be unbonded).
I don't need a bunch of breaker slots, as few as 4 would work fine...
I tend to prefer Siemens or Eaton as those are the same as my existing panels, but I'm having a hard time find a pass-through option that isn't service entrance only....
Am I missing something? Like maybe the way to do this with non-SE panels is via a feed-thru lug kit?
In Siemens, I'd select something like this:
SIEMENS W0404MB1200CT, but this panel is service-entrance only.
An Eaton model is BR816B200RF, but again, it's a "main" and says "service entrance only"
servlet.ImageServer
Bert_
NW Iowa
What are you doing? If we knew the install some we might be able to help better.
Norcal
Details will be helpful, and I would not use a Eaton BR panel or as I call them "Zinsco II" as they are the worst **** even considering GE. There are main breaker mobile home panels that have 8 spaces & feed through lugs.
D
dcg9381
Austin, TX
I need to feed-thru a subpanel (not a service entrance panel), in advance of a generator ATS - purpose is to have the ability to solar upstream of the generator and prevent generator back-feed in the event of a power outage.
D
dcg9381
Austin, TX
I think I found one, 200A, can be configured as service entrance or sub-panel, 200A bus, full feed through on both hots and neutral, 8 breaker spaces:
PW0816B1200TC (cant get amazon to link it)
amazon.com/PW0816B1200TC-200-Amp-8-Space-16-Circuit-Breaker/dp/B005GLDQVI/ref=sr_1_1?dchild=1&keywords=PW0816B1200TC&qid=1607800126&sr=8-1
remove the http and www
