****! feederwires too short what 2 do?
silver78
Fort Worth TX
I'm using #6 wires red,black white and green as feeder wires. They go from a 60amp breaker in the main panel to a sub panel in a new garage. I miscalculted the length of wire I bought. Do I need to buy all new wire or can I use some kind of junction box made for outside mounting and just buy the extra 3' I need to make it into the subpanel?
G_P
Central CT
I dont see why you could not buy the appropriate junction box and use it to extend the wires but it will all depend on what your local code allows.
p_mori7
Montreal, QC., Canada
How far do the wires travel inside the house before they exit to the garage ?
If you have any length inside, I would put my junction box as close as possible to the exit point, then run new wire from the junction box to the house panel.
You will need to leave the junction box 'accessible' and not cover it up ! I would also label it so that anybody else afterwards will know instantly what those big wires are for.
Strouty
Southern Maine
Not as cheap as a junction box, but could you use a disconnect switch?
silver78
Fort Worth TX
Cant move the garage closer...I pushed untill I messed my pants its too heavy
Cant use my wire stretcher...loaned it to my buddy who's puting up fence to keep his unicorn from getting loose
The wires are in conduit that runs up the outside of the garage wall, thats were they end. I need about 3' to continue the wires up through the wall and into the back of the subpanel. Guess Ill check on a junction box thats rated for outside use and meets code.
James-W
Southeastern Wisconsin
How much would new wire cost? If the cost of a new wire would be close to what the cost of installing a junction panel and other stuff would be, then I would just run new wire.
marinusdees
Edgewood, Washington
Had a buddy who did the same thing. Since I was in charge, we bought a large plastic junction box and mounted outside his shop, I connected all extensions with split bolts, wrapped them in rubber tape and then again in friction The classical monkey's paw, if you will. I believe this will pass code. If you're worried, ask the local inspector. If he doesn't like it, ask him what to do. Personally, I just told you what I'd do, without asking any body. PS The "expert" at the local hardware store--not HD or L--s , agreed. My 2 cents worth, not much. I would NOT buy all new wire. Just Me. Be sure to use appropriate clamps and a weatherproof box. This was done 10 years ago. Still working and no fires. Never asked if he had it inspected.
Mustang51js
Haskell nj
You can use a j- box, just need to find out if your allowed split lugs or a non reversible crimp. Around here if it's a small wire like that they usually ask for the non reversible crimp which is easy for me since I have the tools for it. You may need to borrow one. Also what size is the pipe coming up, that will determine the size j-box you need
silver78
Fort Worth TX
Bunch of wise crackers here...I see I found the right place. Gonna do some cost comparison new wire or junction box, also ask mr. Inspector about the box. Thanks for all the ideas fellas.
Milton Shaw
Can you move the new box closer or is the conduit in the slab where it cannot be moved. Otherwise junction box time.
Lotek
Los Angeles, Ca.
"I cut it twice, and it's still too short." :lol_hitti
Would they take it back with a restocking fee if you bought the new wire at the same time? Assuming you buy there regularly, I would think they could help you out. No worse for them than the end of a roll.
EOC_Jason
Bentonville, AR
Yes, I would compare prices see what the j-box, conduit, connectors, etc would all be vs just new wire...
Would a disconnect be useful in that location instead of a j-box?
Or could you save the wire and use it on a later project?
I usually use split-bolt connectors, then wrap them in that thick tape (forgot what its called), then electrical tape. You could also probably use a compression connector. What I think is pretty slick but haven't used personally are those insulated tap connectors which you just tighten down the screws with a hex key...
