wandrur
Some of you may have followed me along (thanks!) the journey of building a 12'x14' motorcycle garage/shed recently. I learned some lessons, but I am definitely proud of the build--it's incredibly functional, and it's more right than it is wrong. Admittedly, I still need to wrap up some finishing touches, including a second coat of paint.
But I have the itch to build again. I have a nice sized property (for my area) at 2.6 acres, but it's shaped like a dogleg running north/south on the long end with the house and drive on the southern portion. The blue box is the motorcycle garage, the yellow box is a 10'x12' TuffShed, and the red box is the anticipated location. Over 2/3rds of the property is covered in 80'+ tall oak trees. Basically, it's a lot of non-functional space unless I build some pathways and sidewalks, and while that sounds like fun...I'd like to make some more useful things in the immediate.
Nearly all of it is also on a significant grade, making it difficult to use for anything level. The target area for the build drops approximately 28" over an east/west length of 20'.
My zoning regs allow accessory structures 256 sq ft and under without filing for a building permit (which also requires some degree of construction plans). That means I could do a 16'x16' to maximize that zoning-only allowance, and it puts the fee at $60 vs $225 plus additionals for a larger build (I could care less on this; it really just depends on what I decide to build).
My plan with this will include 12" diameter Sonotube concrete piers supporting runners followed by a perpendicular wooden foundation. A 16'x16' or 20'x20' would consist of nine piers in the below matrix with any other dimensions basically having a pier every 8'.
I'm sure the question you may have is, "What are your plans? What kind of workshop? Why how what when..." My answer to that is, you know, I'm not really sure. But I'd like to have a place to begin some wood or metal projects like restoring and hafting some old axe heads, building a bookshelf, building an Adirondack chair, or things of that type. However, one justification for going bigger is that I have a 1940s GPW of my Dad's that apparently is destined to belong to me, and it's currently being stored in building my family no longer owns that also happens to be 1500 miles away. Unless I opt to let someone else deal with it, it will need a place to live and hopefully be worked on (Dad hit a tree in the late 1960s, and it's sat since--lots to be done). But there's allegedly no rush on that.
Specced out basic materials for a 16'x16' comes to under $5k, but that doesn't include any windows or doors. I'm in no rush; I'm just having fun working on things.
I know the line is, "No one ever said they wanted a smaller shop." I'm also not building a house here--just a functional space to do some hobby and house stuff.
Please give me your thoughts, suggestions, encouragements, or discouragements.
