Fein tools quality?
Stick-man
Mid-South Tennessee
Fein purchased Slugger, a maker of metal drills, and a few other items like metal saws.
I believe the drills were constructed in the USA, and the saws Taiwan.
I think Fein just rebranded the tools as “Fein Slugger” and added some orange paint to the exterior.
We used the Fein Slugger's at work, and had a lot of issues. First, we were drilling finished product, and with the electronic sensor for the magnet/motor shut off was horrible. We had to grind all paint in order to get them to run.
And, they were breaking left and right. We were using them pretty hard, but switched to Hougen and didn't have any more issues.
jludwig
Fein allegedly did invent the Oscillating “multi-tool”, or at least get a patent on the design for use as a tool.
Fein wasn’t by any means just a “woodworking” power tool manufacturer though.
The oscillating tool design seems to have originally been for medical use, and I believe is the type of saw that may be used for cutting open skulls for autopsies, although the medical tools are branded differently, and I think routinely have the blade oriented at a different angle to the tool (like a die grinder, but oscillating).
The oscillating tools are also used in orthopedics for removing casts, and I’ve come across one or more orthopedic suppliers selling Fein units, since they seem to be cheaper than the versions from medical tool suppliers.
Some of the medical branded versions used to be made by Fein, private label, judging by looks, just in a different color and branding.
The Fein Multimaster, and the Fein vacuums seem to be what got Fein noticed in the woodworking trade, since both were widely available from quality woodworking tool suppliers.
The Fein Multimaster was mostly marketed as a detail sander, even though saw blades were available, probably because the original saw blades sort of sucked. (Fein only included a regular, relatively soft steel saw blade with the Multimasters, and the steel was significantly softer than their HSS blades).
The Fein vacuums, were sold because they were incredibly quiet, and were rated for use with asbestos once outfitted with a hepa filter.
The fein plunge router, as I mentioned above, was manufactured in Italy, by a power tool company called Fellisati.
Fellisatti, seems to have been a known power tool manufacturer in Italy, but outside Italy, the tools were mostly made private label for other brands like Skil and Porter Cable.
Most of the Fein tools marketed to woodworkers, were not actually made by Fein, other than the Multimaster, one or two cordless drills, and a couple random orbit sanders.
Fein tried marketing a jigsaw model in the USA, but it was less versatile than many other cheaper options, such as the Festool Jigsaw and top of the line Bosch jigsaw, because the Fein saw designed for cutting thick steel, unlike the other two.
The German Fein manufactured tools were comparatively expensive, especially compared to other “Industrial Brands” sold in North America, and seem mostly to have been marketed to industrial users.
Fein has had tool distribution in the USA from a headquarters in Pennsylvania, going back probably to the 1950s or 1960s.
Very interesting history - Thank you! Does Fein or Flex make the ASCM 18-4 QMP? The Fein 18V ASCM 18-4 QMP AS and Flex
DD 4G 18.0-EC C look exactly the same.
Anyone have experience with other 4 speed drills like the Hilti SF 10W-22 or Festool TPC?
neophyte
Pennsylvannia
My understanding, was that the four speed Fein drills were bring made in Germany, by Fein,
And one of the Fein Tools dealers foes list the Fein drill as being made in the EU.
Normally, Fein Tools that were made by Fein, were listed as “Made in Germany” in the past.
The Flex drill looks to use a different motor housing than the Fein, but some other controls look the same.
Various German tool manufacturers would routinely share certain components or accessories in the past, or manufacture tools for each other, and Flex used to be a German manufacturer, and I think, still has a German manufacturing facility.
The chuck systems are likely manufactured by a third party, probably either Rohm or Metabo, although Rohm seems more likely.
Fein usually used better chucks than Festool did/does, and Rohm manufactures multiple quality levels of chuck.
I don’t know who is doing the actual design and manufacture of the motors and gear housings.
I used to figure Fein was doing the manufacturing, but Flex is now owned by a major manufacturer of cordless tools, so 🤷.
As for Hilti, there lower priced (under $1,000), tools seem to mostly be made in China now, but I generally don’t see complaints about quality.
