cspcrx
I have been looking at one for a while and followed a few threads on the Femi Hem saws for about a year. Picked a 782xl along with the vertical table attachment shortly after thanks giving and finally got to use it.
First project was building the Mrs. some picture frames for some poster size canvas pictures she got. She wanted raw metal frames to go around them. Picked up some 1.5"x1.5" 16g angle/bent steel. Cut the corners on a 45 so the corners would look nicer. I am so impressed with how accurate and consistent the cuts are. I had on side that came out 1/8 in and one that was 1/16 in over length. Put in back in the saw and was able to shave both of them to the exact length I needed. Holding a 16g 1/16th in L shape slice of steel was so impressive to me.
I also got to use my Strong had 3 axis clamp in a two axis configuration. I know many of you with much more skills have tables, jigs and could do it with magnets. For me it held everything while I tacked it up perfectly. Further showed the quality of the cuts as everything lined up very tight in the corners.
I do not do a lot of metal work so for me this saw is the perfect size. Just not a lot of reviews so I thought I would share my experience with mine. The combination yielded results far better than I honestly thought I was going to get.
It was also my first time welding steel this thin, mostly done 1/8 in. I have a Hobart 210MVP that I am still getting to know. Took a 2 hour welding class last year at a local welding supply store. Between that and YouTube I only made one hole in the material and was able to fill it. Practicing on the scraps helped dial it in.
sorry for rambling on. hopefully someone finds it useful.
