yellowfever
- Joined
- Feb 25, 2026
- Messages
- 32
Hello,
Thanks for the great forum. I am in the market for a double wide 4 post lift for my small two car garage. I am strongly leaning towards Advantage Side by Side Double Lift (see link below) as I like the lift height and not having a post in the middle of my garage (19.5'x19.5' with 16' door and 11.5' height). While reading through the manual, I had a few questions for the group here in case you guys were familiar with this lift:
1. Lifting Capacity shows 10,000lbs - however, they note in the manual:
"Lifting capacity decreases by 25% for wheelbases shorter than 115 inches for each 15-inch increment. With a minimum wheelbase of 70-inches having a lifting capacity of 75% less or 2,500 lbs. This is due to the wheels moving closer to the center of the runway where there is less support."
Unfortunately I am looking to put a couple coupes that have 103-105" wheel base. Total weight shouldn't be more than 8,000lbs but based on guidance in the manual, I may be looking at 7,500-8,000 lbs limit. Am I reading this right? Initially, I am looking to store just one vehicle at the top weighing 4,000lbs so this shouldn't be an issue but it sounds like I may have make sure the second car comes in around 3,500lbs.
2. Manual notes that they don't recommend anchoring to the floor. I live in Illinois so no active earthquakes. I am not planning to move the lift once put into place. Should I anchor down for extra safety? I am concerned just in case someone (wife, more than likely) accidently hit/tap the post while parking.
3. Wiring for the 240V power unit - didn't see much info. I believe they require three wires on a 240v breaker to handle 30amp. Any suggestions on what to tell my electrician other than having 2 power and 1 ground ready for the installer. I presume we could use twist lock to connect between the unit and wall. I also want to put in a kill switch as well. Any best practices to follow here other than keeping the power unit close to the wall socket.
Also would love to hear any other feedback on this lift. Thanks in advance!
Link to the lift:
realgaragelife.com
Link to the lift:
Advantage Side by Side - Double Vehicle 4-Post Lift Maximum Storage
Discover the Advantage Side by Side Lift with a 10,000 lbs capacity, designed for efficient storage of 4 cars on 4 posts, saving space. Perfect for garages vehicles!
