You can run 10G over multi-mode, but not very far. 50 micron works better than 62.5, FWIW. I have a couple short links at work that we are able to do it with, but everything beyond a couple hundred feet has to be single-mode.We're running 10G over old single mode fiber too, which kinda surprised us first time we tried turning up a link. Our 12 year old million bucks worth of multi-mode is no good for 10G. So if you buy fiber, better bone up on what kind for the distance and speed. It's not obsolescence proof.
I went with Cat6 shielded for some hdmi streaming. The problem for me is trying to figure out how to terminate without problems.![]()
We burn them in that way, but we wont run them long term. You can spend whatever you want on networks. Here's our last burn in a few months ago. I wish I could spend that on tools!
cat 6 comes in 1000 foot boxes because that is the limit you can run without another switch to boost signal, i have wired factories with multiple runs for cat 6 back to patch cabinets ,cat 6 will run gigabit with no problem , patch cabinets only used to have 1 cat 6 cable feeding from main coms room with a redundant spare ran alongside
Really ???? Surely you don't believe that Cat 6 is capable of 1000 ft ???
THANK YOU mrjaw, from a fellow network admin.
I am reviving this old thread because it is relevant to the planning I am dong for my new garage in Hiawassee, GA.
I built a new detached garage/shop late last year that is about 350 feet from the house. I trenched and ran power out there to a 100 amp subpanel through conduit. I also laid a second conduit for ethernet, cable TV, phone, anything else I want that is not power. Right now the second conduit has no wires in it, just a pull string. I did not know to keep the two conduits spaced apart from each other, so that might be a problem...
I was planning to run a couple of Cat5 or Cat6 out through the conduit, plus a few other wires, like cable TV. I would like to have a high speed link out there to my shop to access big files stored on the computer in the house. I brought the conduit right into the room in the house where the big computer is.
Can Cat6 handle this distance?
I was thinking that it might need to be fiber, which is how I ended up in this year-old thread.
It really ought to have been posted as a new stand-alone thread; but that's water under the bridge at this point.
It won't help; but it's also not very likely to be a huge problem, as long as there was SOME separation (even if only an inch or two) between the two conduits when they were laid in the trench. The point is to avoid induced signals in the low-voltage lines, due to their close proximity to "heavy" current-carrying conductors. You can easily enough test for this by simply running some (2 or more conductor) wire in that second conduit, tie the two conductors together at one end with a fairly high-value (100k Ohm to maybe 1M Ohm, perhaps) resistor, and measuring for AC voltage at the other end using a high-impedance VTVM, or an oscilloscope. If you get no more than a few microvolts, you're good to go. BTW... For the test to be valid, you need to turn on EVERYTHING in the shop, so as to produce the maximum possible current flow through the feeder cable during the test.
As noted by others, "CAT-6", per se is not the issue; "Ethernet" is the issue.
Officially, the maximum TOTAL length for any one Ethernet segment is 100 Meters (~328 feet), INCLUDING the patch cables at each end. If you keep the patch cables as short as possible, there is a fair chance that you could "get away with" 350 feet; but your effective throughput, collision rate, dropped frames, etc. will likely all be somewhat short of ideal.
You don't want to mess with fiber. It would be an expensive PITA for this application.
If simply "stretching the spec" does not produce the results you're looking for, one possible approach would be to re-open the trench somewhere near the middle of the run, then dig a hole nearby big enough to accommodate a moderate-size all plastic and completely sealable NEMA enclosure. (You'll want at least NEMA Type 4; preferably Type 6 or 6P) Re-arrange the conduit to run into, and back out of that enclosure. Make certain that ALL of the connections are thoroughly sealed. In the enclosure, put a small inexpensive Ethernet switch, such as (just for example):
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704042
Ideally, you want one which does the AC/DC rectification (and at least some of the smoothing/regulation) within the wall wart itself, as opposed to simply feeding reduced-voltage AC into the unit; but it's not a big deal.
Now you're going to need to do some "surgery" to the switch's "wall wart" power supply: Making VERY sure to keep polarity straight, cut the cord between the wall wart and the plug which connects to the switch. Run some appropriate wire (need not be anything "heavy"; one AWG grade up from whatever the stock wall wart used will be fine) from whichever end of the conduit is closer (I'm guessing the shop/garage) to your new NEMA box. Splice the wires from the wall wart and the plug to each end (again, polarity is CRITICAL, if it is a DC feed), as appropriate. Plug in the wall wart and test your Ethernet connection(s). Assuming that goes well, seal up the box, bury the whole thing, and don't look back. (You MIGHT want to buy a second switch at the same time, so as to have a ready spare if/when the seal on your underground NEMA enclosure fails, and the switch gets trashed by water or similar. They're certainly cheap enough.)
Keep it as tight as you can. It's not as big of a deal as people make it out to be. Plus, you will never know unless you certify it. ( about 5k worth of test gear) Cat 5E speeds (gigabit) are easily attainable and more than sufficient.
--FIRST POST![]()
If you go through this whole process of digging a hole, it'd be easier to just run POE that distance to a small switch versus hacking up a wall wart/etc. I have a couple outdoor access points that I use the D-Link POE injectors/splitters ($30) with and they work great… provides 1A @ 12v. This ups the voltage to send it over the cable and then lowers it at the destination so current is not a big issue.
Yes, the POE voltage is higher, so it will work better over a distance than a 12V adapter, but the voltage drop over that distance may be so much that it will not power up the switch at the other end.
