NWOhioChevyGuy
OK, years ago I placed some mounts on top of my ARE fiberglass cap to haul four kayaks. The cap didn't like the weight and cracked at the corners by the rear door, top two corners. I fixed that with some fiberglass and have not hauled that type if weight on top since.
Now that my kids are out of the house I will be hauling only two kayaks and plan to rework my rack for the truck so I don't have to pull a trailer with me on trips.
I have 1" square steel tubing (1/8" wall) from other rack / trailer rack projects that I will reuse.
This rack will be external to my cap, mounting to the same points on top of the cap as used before but have "legs" on the outside of the cap to bear the weight onto the bedside utilizing some 3.5"x6" angle iron as "feet".
Question is should I weld the feet on the inside of the legs or outside of the legs?
Sketches in the pictures below.
