Fiberglass insulation service temp limits?
sberry
Brethren, Michigan
It worked with no negative affects the first several times I did it.
My guess, flames were 10 ft tall.
The smoker was pretty well engulfed on all sides.
I was using 2 layers of foil backed insulation (foil on both sides). I pulled the flaming material away from the smoker with a rake. There was
not much structure left to the fiberglass. It was no longer batts, just a bunch of small charred pieces.
Did it get oil soaked? Glass wouldn't bother me in a smoker.
M
Marctrees
TX/LA border - Toledo Bend
It seems the FB insul is more than suitable with the only question being the additive binder.
And even then, should be ok for a electric smoker cabinet temps.
Not proposing it for a ceramic kiln. Marc
