Fiinally showing it off! My Garagemahal
absintheisfun
I have been lurking for a while and looking for advice. I now feel like I can show it all off. Thanks to all the ideas and advice I found on this forum!!
I always knew that I was going to epoxy the floors, so I wasn’t very kind to the existing concrete:
I stashed all of my tools and items of worth in the back room of my house. Everything else in the back yard for a week!
-it’s amazing what a good grinding, acid cleaning and pressure wash will do!
Before putting down the epoxy, I scraped the popcorn
The gray epoxy was intentionally done with very sparse flecks. Just enough to distract from imperfections and dirt
Re-Tape and bed the seams
Prime and paint the ceiling.
Then it was time to patch the holes and paint the walls.
The black stripe was actually done with rattle can. I painted my 63 C10 with this stuff, and thought it looked pretty good, so why not continue using it? I had 12 extra cans just sitting around
I got two walls done and then starting moving back in !!!
Piled everything from the third wall on a blanket on the floor and painted that.
Insulated the garage door and added A/C. It doesn’t put frost on anything, but it makes one hell of a difference!
Door open: Outside 105, Inside 105
Door closed: Outside 105, Inside 120+ (thermometer only went to 120 and the mercury was pegged!)
Added A/C: Outside 105, Inside 90
Insulated the door: Outside 105, Inside 87
Added a fan behind the A/C: Outside 105, Inside 82
AWESOMENESS! And if you are wondering how it was 105 for all of these tests, it was over several days and the temp for Dallas was 105 every day! We picked August in Dallas to redo the garage (I’m smart huh?):lol_hitti
So after 6 days in the sweltering August sun, it is complete:
Behind the extention cords is my hidden compressor:
I added a “ramp up” to the garage. The step is only a couple of inches, but figured why not:
I have a bank of 9 on-off switches that were wired to accept plugs in the back. I built a box around it and have all of my chargers and fluorescent lights hooked up to it.
I threw a breaker when I had all 9 switches running, the A/C and a few other accessories on the same circuit. (Basically it takes a hell of a lot of drain to get it to throw. I over-killed it on purpose to see the circuit’s limit)
I built all of my workbenches to be completely static. With the “ramp-up” curbs on the sides, it made it difficult to put anything on wheels against the wall. You can see the scorch marks where I tacked the legs together while against the wall.
All of the benches were built to have easily replacable surfaces.
Thanks again for the the help and advice!
q20v
Ottawa, ON
Did you seriously do ALL that in 6 days?!?!? It took me that long just to mud/sand/paint my walls!
Garage looks really nice, very clean and organized. Good work!
A
absintheisfun
Pardon me for asking... but WTF???
It is basically the same thing as a power strip, only it has a switch for each plug, rather than all 9 being either "on" or "off" together.
I am absolutely in love with this thing. A place I used to work (Lighting manufacturer) had this a display so they could turn on and off individual lights at a trade show booth.
After the trade show, the booth was demolished and this switch set was trashed. I quickly grabbed it and brought it home.
A
absintheisfun
I quit my job to go back to school...so 6 days is seriously 6 days...about 10-12 hours per day!
Class starts Monday, so my free time (approximately 24 hours per day) will go away real fast!
Ocho
DFW, Texas
How many btu is your A/C? 82 in the garage/105 outside is a fantastic result.
I'm in D/FW as well and redoing my garage in August. :wtf:
Yep. It's hot. :evil::evil::evil:
A
absintheisfun
Nice.
Cant the compressor breath in there?
The door opens, so in the summer when I run it, I leave the door open if I run it quite a bit (the top also comes off). In the winter I leave it closed and it never really warms up too much. There is a 6"-10" gap at the bottom where plenty of fresh air gets pulled in.
Insulate, insulate, insulate! The A/C unit is from Lowes and it is 12,000BTU A/C with a supplimental heater.
I have it set to dehumidify (really makes a huge difference), fan on high and the fan behind it on high to circulate the cooler air.
I also made an almost-sealed exhaust for it through the side door to my back yard. I'll get some better pics of it up tomorrow.
bchee
Texas
6 days??
I thought you couldn't put anything on the floor for AT LEAST a few days.
A
absintheisfun
6 days??
The epoxy went down Friday morning. 24 hours later you can walk on it, so we put down a canvas tarp (so it could still breathe) and started painting the ceiling and walls. We finally put cars on it today!
CrashTestDummy
Nice work. When the 'compressor closet' door is closed, does it deaden any of the compressor sound? I know it's vented at the bottom, but just wondering. I'm trying to figure out what I'll be doing with the compressor in our shop. I'm currently thinking of putting in a little plastic garden shed outside, in a 'carport' area, but if you can get enough sound deadening, inside would be better, IMHO.
I'd _think_ I'd be using the jack stands in the garage a LOT more often than those gallon cans of paint. I'd swap them so the jackstands are easier to pull down. I'm not 7'4" tall, so like PaulR, I'd be dropping jackstands on my head a lot. :)
Gene Beaird,
Pearland, Texas
Fishwacker
El Cajon, CA
X3, is that even legal?
RUMBLON.
Nice build so far.
:thumbup:
It ain't illegal 'til ya get caught or the house burns down and your insurance company finds this to be the cause. Then cancels you just to make you feel better. Ditto on the nice build comments, but it'd be a shame to lose it due to a salvaged switch panel. Especially if there are any children in you family. Trust me, they have no problem testing to see what all those switches do just for fun.:headscrat
TejasBimmer
off I-35, TEXAS!
Great redo.... I live more South (New Braunfels) than you (hence hotter) and wondered if one of those AC units would work. Is all your walls and ceiling also insulated (other than the garage door)?
As for the salvaged gang plug... I would hard wire it correctly.
Nighttrain
Dripping Springs, Tx
Nice work, and good luck going back to school. As for the plugs I'm not an electrician but to me that looks OK. Those are heavy duty plugs, boxes and wire. If we all saw the whole set up it looks like its just being used like any power strip cord but instead of one switch with 8 or 10 plugs he has a switch per plug. Using each to power a cordless drill. I would have to label the switches on the front be cause I would never remember which is for each cordless charger. (What's the hood for?)
Jim
Further down I-35 in the Hill Country
A
absintheisfun
where is the car that goes under that hood?
good work on organizing everything! that's alot of work in 6 days!
The Camaro is getting the frame alligned and quarters put on. I have done all of the body work so far, and will finish the car, but was too nervous and inexperienced to handle the quarters!
And as far as the on-going debate of the plug...
1. Ever had a power strip that takes 6, 9, 12, 18 plugs? This is the same thing only it has an "on-off" switch for each plug, rather than a master reset/off switch for all the plugs at once.
2. It is safe, wired and built by an electrical engineer at a lighting manufacturing company.
3. It is safer than most any power strip you have around the house because when I am not in the garage, it gets unplugged from the main plug.
4. As "famous last words" as this sounds. . .I have had this for 4 years and never had a problem because I am so careful with it.
wilb1976
Maui
Stupid question, but do I need photobucket pro to view the images in this thread or am I doing something wrong? Can someone re-post images so photobucket isn't needed? I would really like to see what everyone is complimenting.
e-tek
Saskatoon, SK
This happened to my PB account too. Have to pay $25 to get all the bandwidth you want. Then these will come back. I hope the OP does, 'cause I WANT to see them!!
Although I haven't actually SEEN the power strip, this is likely another example of the "sky-is-falling" bandwagon....give it up guys, the sky rarely falls in real life!
