File sleeve or other idea road box?
uscarry45
Any good ideas to store a standard ******* machinist file in road tool box?
RoninB4
Under My House
Cardboard tube or capped PVC are good ideas. Whatever you choose a wash of the interior with any type of petroleum based oil will help prevent the file from rusting, which will surely happen in a road box. Rust on a file will blunt the cutting teeth, making it useless when you need it. The interior doesn't need to be dripping with oil, a thin film will do. I'd do the threaded cap PVC if it were me, more durable and better to seal out moisture.
KnurledNut
n/a
The plastic sleeves that lift supports come in (gas shocks for hoods etc) work well.
Also might check out kitchen knife sheaths, guards.
Pictured below is a Dexter 20400:
Make one out of an old cereal box and a roll of packing tape? Can make two pieces so you have a sliding cap.
If you use froot loops, say it’s your kids cereal.
ecotec
I have always left mine loose and uncovered in my hand box for the last 30 years.
Are you more worried about it rusting or hurting the tools next to it?
Every once in a while, I de-pin it and put a little oil from the pipe threader on it.
If you are worried about the file rubbing against the other tools… 30 years of carrying a hand box and the damage the file has done to other tools is negligible.
Technically, a hand file is not on our tool list. They are technically a contractor supplied tool. I always carry my own. It is easier than going to search for a contractor supplied one.
I used BenchTop that I got NOS about 30 years ago.
U
uscarry45
I like all the ideas. I am leaning towards the leather or plastic sheath idea. I would like to keep it from rusting and from having other tools rub against them. Ideally it would retain a little bit of oil to keep rust at bay but not enough to attract dirt. Also thinking about lay flat hose any ideas to seal one end? Glue? Heat seal?
WWheeler
Middleofnowhere USA
I keep flat files, rasps, chain saw files and needle files in a small plastic parts storage box, the kind with dividers you can rearrange, that sits on a shelf out in my garage/shop. I also keep a few such files in the slots of the top removable tray of a small plastic tool box in the work truck.
CS454
Rag + stolen hair tie. Lasted longer than the elastics.
tarbellb
Oregon
fancy- leather and rivet
surprising good- cereal box and duct tape
PVC seems like a lot wasted space
KnurledNut
n/a
Copper.
If you flatten the end, it also gives you a file cleaning tool.
yhprum
Brisbane Australia
Forgot to add I use the packaging if I buy a new file.
U
uscarry45
This is the reason I love this forum. Lots of great ideas from cheap to innovative! Simplistic to more creative. Thanks very much!
tarbellb
Oregon
Sell the files, equip the vehicle with onboard air, plumb lines, and buy every grinder type possible.
