Fill cut lines before or after acid staining / polyurea application?
STINEY
Bucyrus Ohio
So what is the concensus?
Is it best to apply the acid stain and polyurea coating first, then mask and fill the relief cuts?
Or is it better to fill the cuts first, then apply the coatings?
I plan on using a self-leveling sealant like Sika SL or Extreme set 100. Will either of these "take" stain or will they stand out visually no matter which way I go?
rnixon
I filled the joints after acid staining. I used 1/4" Screen moulding , in the joint ,to help get a straight tape line [ made it easy ] Polyurea afterward, sealed the edge of the Sika Flex
Armorpoxy
Always fill after, as Legacy is correct the fillers won’t take the stain.
Check out Metzger and McGuire Brand Rs-88 joint filler, comes in 100 colors.
