Filling a low area - or not
cwrandolph
Sidney, Ohio
I have a oval shaped low area (about 18" X 24" X 1/4" deep) that collects water if I wash a car inside or from rain/melting snow dripping from a car. Since I am working towards putting new coating on my garage floor I am considering filling this area. Originally I planned on leaving it alone since it's fairly close to the door and I can just squeegee the water out. But now is the time if I plan on fixing it. What can I use that can be feathered out at the edges and won't be noticeable when coated? I'm leaning towards a Polyurea coating and plan on using a primer. Thanks in advance for any advice.
Marctrees
TX/LA border - Toledo Bend
Well, I said a long paragraph about OCD, then realized it is not MY ... MY.... job to correct some other persons ... In MY view.... Overfocus on what is in MY OPINION, a NON issue.
Marc
Marctrees
There is an entire concept in Life to understand thaat..."It is NOT MY job to tell someone they are wrong"
Ya.... that is NOT just some ******** MY idea... but some WISDOM to SOAK IN.
I already said tooooo much.
Willypu
East Of Eugene Oregon
If the spot bugs you enough that you notice it all the time, I say to fix it.
Probably a good time to get all the low spots, cracks and divots if you plan to go through the process of putting on a new covering.
Good luck with the project!
rsanter
visalia ca
How about saw cutting a few grooves 1/4” deep to allow a drain channel for the water to drain from that low spot.
Then coat the floor
James-W
Southeastern Wisconsin
They do have some self leveling floor stuff that you just pour out onto the floor. You might want to try that, not sure what it costs though.
gemniii
Fulton, Ms
Yes, but how to fix it?
Any recommended brands from personal experience?
I've a similar problem.
I've 2 "ponding areas" on my 40 yr old concrete front porch, each about 10' x 10'. Rain puddles up to about 1/2" deep in the center and feathers to the edge. In my Mississippi climate the puddles may last for a week before drying up. Algae grows and dries, creating a mess which must be blasted off.
I'm looking for a product that will "level fill" the area and feather to the edge. It needs to bond TIGHT to the concrete porch and not "spall" off with the occasional freeze/thaw. And shouldn't crack easily on it's own.
So far quikrete "floor resurfacer - self leveling" and sakrete "Flo-Coat Resurfacer" are my two top candidates. But the quikrete is labeled for indoor use and the sakrete is not "self leveling".
Shea
California
Filling small "bird baths" like this can be problematic. Part of the problem is that the product has to be ground down to a feathered edge. Feathered edges can be weak. Also, self-leveling is more of a misnomer as they don't self-level like you would think. Most repair products that you can pour like a liquid are polymer-modified cements. They do not cure as strong when mixed to that state. Do not confuse self-leveling products with underlayments. These are not wear surfaces and are designed for indoor use only to be used under tile, wood, carpet and etc.
Since it's a coating that you want to apply, your best bet would be to fill that area with a 100% solids epoxy. You can mix a batch up, pour it out onto the floor near the depression and then pull it over using a squeegee that is wide enough to bridge the depression.
You would need to grind the area to prep it for the epoxy first and then grind the epoxy flush with the rest of the concrete after it has cured. The epoxy will take to a feathered edge much better than a polymer-modified repair patch.
Of course something to consider is that a repair such as that will most likely cost close to $100 for the epoxy. Also, a question to ask yourself is where will the water go that is now being displaced?
