filling cracks in a cutting board what do u use ?
stitan06
so i decided to make a end grain butcher block cutting board the prob is some of the wood i used was not straight and when i glued together i got some small gaps what do the guys that do wood working use to fill something like this ?
OHMS LAW
Houston TX
I have seen bees wax used. I wouldn't use anything stronger than that since your food would be on it.
Norcal
I am not sure there is anything that would be food safe to use as a filler on a wooden cutting board, but then again there are the food safety Nazi's who say one should not even use wooden cutting boards. :D
brownbagg
the epoxy will get into your food, just leave the cracks, its a cutting board
rlitman
Long Island
I'm a food safety nut, and I know well that wood cutting boards have the potential to be more sanitary than plastic.
If it were me, the first thing I'd try to do, would be to swell the wood gaps shut.
Pour some hot salty water into them.
Steroblan
Northern Calif
It depends on how big the cracks are. You don't want them to fill up with food. Get the epoxy made for wood floors. Don't use epoxy for metal (JB Weld or similar). The epoxy won't be much worse than the glue will it?
rsanter
visalia ca
what glue did you use in the original glue up?
I would use some of the same glue, mix as a paste with sawdust and fill the cracks with that and then sand
bob
johno
Southern Ont.
bob
That's what I would do^^^^ depending what kind of glue you used.
KenC
oklahoma
IMO, the best, easiest and fastest fix is to just cut the board apart at the crack and reglue. It should fit back together at the cut perfectly, if you are using an appropriate blade.
